FAO Ikarus
- Topic Author
16 years 1 month ago #29759
FAO Ikarus was created by PureEvilDevelopments
as discussed at rising sun mate these are the 2 subs i was thinking of if i was to add an install to my car
Rockford Fosgate P3SD410 Shallow Subwoofer
Specifications:
Impedance: 4-Ohm x 2
Power Handling: 300 Watts RMS, 600 Watts Max
Voice Coil Diameter: 2.5" 4-Layer (6.35 cm)
Motor Size: 46 oz.
Speaker Connector: Dual 10 AWG compression
Fs (Hz): 45
Re (Ohms): 6.80
Le (mH): 3.6
Qms: 4.50
Qes: 0.87
Qts: 0.73
Vas (Liters): 10.4
Sd (cm2): 310
SPL (1w/1m): 83 dB
Xmax (mm): 10.8
Woofer Displacement: 0.061 cu. ft. (1.73 Liters)
Cutout Diameter: 9.0 in. (22.86 cm)
Mounting Depth: 3.50 in. (8.89 cm)
Shipping Weight: 13.40 Lbs. (6.07 Kg.)
Rockford Fosgate P3SD412 Shallow Subwoofer
Specifications:
Power Handling: 400 Watts RMS, 800 Watts Max
Motor Size: 52 oz.
Fs (Hz): 45
Re (Ohms): 6.80
Le (mH): 3.8
Qms: 4.60
Qes: 0.88
Qts: 0.74
Vas (Liters): 21.0
Sd (cm2): 450
SPL (1w/1m): 86 dB
Xmax (mm): 10.8
Woofer Displacement: 0.071 cu. ft. (2.01 Liters)
Cutout Diameter: 11.125 in. (28.26 cm)
Mounting Depth: 3.625 in. (9.21 cm)
Shipping Weight: 16.30 Lbs. (7.39 Kg.)
if you can work your magic and advise it would be greatly appreciated
Specifications:
Motor Size: 46 oz.
Fs (Hz): 45
Re (Ohms): 6.80
Le (mH): 3.6
Qms: 4.50
Qes: 0.87
Qts: 0.73
Vas (Liters): 10.4
Sd (cm2): 310
SPL (1w/1m): 83 dB
Xmax (mm): 10.8
Specifications:
Motor Size: 52 oz.
Fs (Hz): 45
Re (Ohms): 6.80
Le (mH): 3.8
Qms: 4.60
Qes: 0.88
Qts: 0.74
Vas (Liters): 21.0
Sd (cm2): 450
SPL (1w/1m): 86 dB
Xmax (mm): 10.8
16 years 1 month ago #29760
by Ikarus
Replied by Ikarus on topic Re:FAO Ikarus
Will have a look into it for you bud once i'm the other side of japfest
- Topic Author
16 years 1 month ago #29764
Replied by PureEvilDevelopments on topic Re:FAO Ikarus
thats fine mate thanks
Time to create page: 0.057 seconds
- FAO Ikarus
