× J-n-C Project Cars
Tonys GT4
19 years 1 month ago #15033 by PureEvilDevelopments
Replied by PureEvilDevelopments on topic Re:Tonys GT4
Celica GT4 and easy do not go together
the pipework will need fabricating we are going to do as much as we can but think phil at unique exhausts may be called on for some assistance
Jim<br><br>Post edited by: Pure Evil Developments, at: 2007/07/01 19:15
19 years 1 month ago #15040 by sausagefingers
Replied by sausagefingers on topic Re:Tonys GT4
lookin good lads sorry i didnt get chance to lend a hand but u no what women and shopping are like
greg
18 years 11 months ago #17233 by Teenage Kicks
Replied by Teenage Kicks on topic Re:Tonys GT4
Well i thought i'd update this thread with whats happed recently with the GT4.
Firstly, Dave worked is magic and fitted my Apexi AVC-R and PLX R500 (still need to get an adapter plate made for the Wideband Sensor, as the standard sensor has a typical wierd toyota fitment :angry: ....)
Next, getting back to the previous posts concerning the intercooler........ After a good few hours of work over two days and alot of sweat, tears and gratuitous swearing the pipework was installed by myself (1st mistake! :lol: ) but there has been a few technical problems.......... firstly, i can't go above 0.5 bar because the pipes keep popping off (While going round a round-about! :angry: ) and the samco coming off the turbo to the intercooler which i'm not happy with, and a snagging from the pipework on the underside of the bonnet (Thanks again to Dave, Minty and the angle grinder :ohmy: )
But hopefully, tomorrow i should have the problems sorted, as i have decided to take toyota's example of over engineering and use about fifty clamps and a foot of samco on each side of each joint :silly: and i should be back to running 1.0 bar.
I'll get some photos and post them up tomorrow after i've done the work.
1992 Toyota Celica ST185 GT-Four Widebody
1997 Toyota Celica ST202 GT
CARAI AN SHEN AN CALHAR!!!!!
18 years 11 months ago #17236 by Pabz
Replied by Pabz on topic Re:Tonys GT4
sounds like you are doing a good job mate, hope it goes together right
18 years 10 months ago #17799 by gtir350
Replied by gtir350 on topic Re:Tonys GT4
So do you have a final spec your going for now ?
18 years 10 months ago - 18 years 10 months ago #17966 by Teenage Kicks
Just thought i'd post this up, this is the ECU i'm going for -
LinkPlus G3 -
Engine Configurations:
- 2-12 Cylinder Distributed
- 2-12 Cylinder Wasted Spark
- 2-8 Cylinder Direct Spark
- 2 Rotor
- User Configurable Firing Order
Fueling Adjustments:
- Up to 440 Zone Fuel Table with configurable load and RPM centres. MGP, MAP and load options.
- Dual Fuel Tables
- Up to 4D Fuel Mapping
- Injection Rate
- Master Enrichment
- Pre Crank Prime
- Crank Enrichment
- Post Start Enrichment
- Warm Up Enrichment
- Acceleration Enrichment
- IAT Fuel Correction
- Injector Deadtime
- Overrun Fuel Cut
- Idle Load Trims
- Fuel Temperature Correction
Ignition Adjustments:
- Crank Dwell Extension
- Maximum Advance
- Spark Duration
- Dwell Time
- Up to 440 Zone Ignition Table with configurable load and RPM centres. MGP, MAP and TPS load options.
- Dual Ignition Tables
- Up to 4D Ignition Mapping
- Individual Cylinder Ignition Trim
Processing:
- 40 MHz Specialised Automotive Microprocessor
- Ignition control to 0.1 degree, fuel to 0.01 ms
- 32 Bit Calculation
- 10 Bit ADC Resolution
- Max 20000 RPM
Inputs/Outputs
- 8 High Current Injector Drives
- 8 Ignition Channels
- 8 Auxiliary Outputs
- 8 Digital Inputs
- +5V Out
- +8V Out
- 4 Temperature Inputs
- 6 0-5V Analog Inputs
- 3 Load Inputs (MAP, TPS, MAF)
- 2 Trigger Inputs (Reluctor, Optical or Hall Sensors)
- 2 Knock Inputs
Communications:
- On Board USB (Tuning Port)
- Serial RS232
- CAN
Analog Inputs:
- Wideband O2 (from external controller)
- Boost Adjust Signal
- Voltage (0-5V)
- Pyro (from external controller)
- General Purpose Pressure
- MAP (user selectable MAP sensor type)
-Throttle Position
Boost Control:
- Engine Temp Correction
- IAT Correction
- Dual Boost Tables
Limits:
- Engine Temperature Dependent Soft and Hard RPM Limit
- Engine Temperature Dependent Soft and Hard Boost Limit
- Vehicle Speed Limit
- System Voltage Limit
Triggering:
- Digital Trigger Decoding
- Reluctor, Optical or Hall Sensors
- Programmable filtering and arming thresholds
- Configurable trigger patterns or preset triggering options.
MotorSport Features:
- Antilag (Group A and Group N modes)
- Launch/Traction Control
- Flat Shifting
Auxiliary Output Options:
- General Purpose Output
- General Purpose PWM
- Continuously Variable Valve Timing Control
- Closed Loop Idle Speed Control (Solenoid or Stepper)
- Fuel Pump
- Fuel Pump Speed Control
- Engine Fan
- Air Con Clutch
- Air Con Fan
- Intercooler Spray
- Tacho
- Check Engine Light
- Purge Solenoid
Idle Control:
- Open Loop or Sophisticated Closed Loop Control
- Solenoid or Stepper Motor ISC Valve
- Aircon, Engine Fan or Power Steer idle up
Temperature Inputs:
- Custom or preset temperature sensors (IAT, ECT, Fuel Temp. or General Purpose Temp.)
Tony
Last edit: 18 years 10 months ago by Teenage Kicks.
18 years 9 months ago #18735 by Teenage Kicks
Right, well turbo is back from being hybridised, Looks like new and i'm really happy with it.
Stats and figues should be available soon, and i'll post them up as i get them, but i've been told roughly that it'll easily cope with 1.5 bar with out any problems and be well capable of producing well over 400bhp :) :) :)
I'll post some pics up as soon as i can (Along with pictures of the FMIC as i said i would in the above post).
Tony
18 years 9 months ago #18737 by Chick~With~A~CRX
Replied by Chick~With~A~CRX on topic Re:Tonys GT4
go tony!!! cant wait to see the gt4 running after this goes on!!!
Glad your really pleased with it!!
18 years 9 months ago #18746 by hadyn
Replied by hadyn on topic Re:Tonys GT4
I look forward to seeing this in the flesh - looks uber nice :)
Visit the forums @
www.octaneboost.co.uk
18 years 9 months ago #18755 by tommo
Replied by tommo on topic Re:Tonys GT4
will be when its finished! GOOOOOOOOOOOOO TONY.......
18 years 9 months ago #18979 by Teenage Kicks
As some of you know, i was having some electrical problems with the GT4, Plus the 3 things that it failed on in the MOT.
Well, i'll start with the MOT Fails first,
1.No Rear Fog Light
2.Movement in the steering column
3.Exhaust too loud :)
First things first, i fitted a bolt on Fog Light (Bloody awful things) and wired it up (Which inevitably caused my Little Electrical Problems.... Me and electrics do not go well together), but the fog light is working.
secondly, the steering column, after fearing that the steering rack was knackered, i was pleased to learn that the only thing it needed was a bit of TLC, The associated bolts were cleaned, greased and re-tightened and the movement is now eliminated.
Thirdly, the GT4 paid a visit to Phil at Unique Exhausts, and after discovering that the silencer that was already on the car was buggered, Phil made a new one up and also made a bung for the tail pipe, and the GT4 is now quiet(ish).
So with those thing done, the GT4 should pass the MOT retest.
Now, onto the slight electrical problems,
Firstly, i was having trouble with my battery not being able to hold and kind of charge, i believe i have sorted this, as the Main earth from the battery (Battery is in the boot) was far to thin a gauge to complete the circuit sufficiently. But it now seems to be working as it should be.
Next, The Electrical problems that were caused by myself when i was fitting the Fog light..., Basically the following stopped working - Cigarette lighter, Clock, Stereo/Radio, Electric Mirrors and Heaters. After countless Hours trying to rectify the problem, i went through the wiring diagrams again for about the 5th time, and noticed that all the effected systems were running off the same fuse, the fuse for the Cig Lighter. After checking the fuse and finding it had blown. now replaced the interior electrics are all working fine and it's all good again.
18 years 9 months ago #18981 by S.Coupe
Replied by S.Coupe on topic Re:Tonys GT4
Good show Tony
I'm guessing that parts 1) and 2) and transitional arrangements :laugh: :laugh:
Actually, I'd like to ask you a question about wiring since you seem pretty proficient (mention of wiring diagrams..) my rear fog was wired into one of my reverse lights to pass ESVA. It really bugs me because people keep telling me that one of my reverse lights does not work. How do you think they wired that? I would really like to put it back to how it should be. I don't have to worry about the MOT for a couple of years still so it's worth it I think.
Stu.
Blue JDM Skyline Coupe (V35)
18 years 9 months ago - 18 years 9 months ago #18984 by Teenage Kicks
Well stu, What i'll say is this....
The GT4 was the same, 1 reverse light was used as a Fog, when i attempted to re-wire so i'd have 2 reverse lights and a fog light, i ended up with a fog light switch that when you turned it on, both reverse lights came on....... I'm absolutly useless with electrics mate, i really am.
But, basically what the importer did with mine was cut one of the wires to the Drivers side reverse light, ran a length of cable from the former reverse light to a fog light switch, then using the power feed to the ignition harness they fed the live power cable to the fog light switch and finally a ground from the switch to a earthing point.
What i did (Probably the most stupid way around it tho) was to re-attach the cut wire to the reverse light, which sorts out the reverse light bit, then from the back of the fog light switch i ran a cable directly to the battery, a wire directly to the fog light and re-used the earthing wire.
The idiotic thing i did do (Which was why i had the interior electics problem afterwards) was to run the power for the fog light from the stereo power feed, which then unceremoniously blew the fuse, hence why i ran the power directly from the battery
To be honest you'd be better off asking someone who has more knowledge about electrics than me, seriously everytime i touch the electrics on the GT4, i bugger it up, and there has been a few examples....... Strangely enough tho, the electrical stuff i've done to the other celica, has turned out ok.................
Last edit: 18 years 9 months ago by Teenage Kicks.
18 years 9 months ago #18987 by S.Coupe
OK, I get that.
I don't care about a fog light at all (In fact the people that converted my reverse light didn't change the bulb, so I have a white fog light !!!) So I just need to re-attach the cut reverse light wire, but where d'you think they cut it - somewhere in the engine bay or near the back of the car? Where would you guess?
Cheers Tony
Stu.
18 years 9 months ago #18988 by Teenage Kicks
I would say it's more likely to be at the back near the light cluster, on mine it was cut about 2 inches from the bulb.
Tony
Time to create page: 0.191 seconds
