good early morning
19 years 9 months ago #8613
by gtirpaul
good early morning was created by gtirpaul
as i am up at stupid o' clock this morning ringin par in australia to give them a bollocking i thought i would just say good mornin to you all as im never on in the day to say hi now im goin back to bed 8-)
19 years 9 months ago #8614
Replied by gtir350 on topic Re: good early morning
[smiley=2vrolijk_08.gif]
and they said ----?
and they said ----?
19 years 9 months ago #8618
by gtirpaul
Replied by gtirpaul on topic Re: good early morning
lol they said i had to email them and they would pull up my file and get back to me >
19 years 9 months ago #8619
Info I found
17 / 19 mm tags
PAR were also informed about this once i found out all the details and now they make rods either for 17mm or 19mm bearings (need to specify when ordering).
DS
17 / 19 mm tags
DS
19 years 9 months ago #8627
As i'm in a helpfull mood, and good at web searching. ( this might be helpfull ? )
The rods and crank aren't any different between the two motors but the rod bearing shells are. The Gti-R has 19mm wide rod bearings while other SR20's have 17mm wide bearings. The 19mm bearing has more surface area and a higher load rating. You can use 17mm bearings or 19mm bearings with any SR20 crank. The bearing locating tang (tab) is in a different spot for the Gti-R bearing so you would have to modify the rod if you go with a different bearing size than it originally used. All the JWT rods have slots for both types of bearing tangs.
19 years 9 months ago #8633
Replied by sausagefingers on topic Re: good early morning
my u were in a researchy mood dave.
i managed to get my bonnet prepped completly this afternoon and even started paintin the underside
greg
greg
Time to create page: 0.091 seconds
Gossip Room
- good early morning
