Latest GTiR - Build Up
18 years 2 weeks ago - 14 years 2 weeks ago #23400 by gtir350
My 3rd GTiR Story
Ok, so after checking my previous green pulsar, the shell wasnt looking to good with arch rust showing up and when checking under the arch it was all rotton :(
But at the same time a very good item came up for sale.
A mint shell :)
The Below was taken from the advert for the shell
The shell has every single whiteline option including all bush options/both ARB's/Anti dive kit/NEW bump steer kit/New powder coated front wish bones with new ball joints/Nismo KYB susp/2 new chassis rails/rust treated and painted underside/poly gear linkage bushes/poly steering rack bushes/new power steering pipe work/new brake lines/all non load nuts and bolts have been replaced with stainless/Walbro fuel pump and all other bolts holes and bolts/nuts have been re tapped and copper slipped for ease of dis assembly .
Oh and it's been re painted Ferrari Metallic Nero, I just had the one of the front wings and front bumper re done
Most of the whinline kit was removed before sale, buts everything else inside and out was good and only needed a few things to be looked at to get it 100% tho.
These pics are from the previous owner..
Then the shell was delivered to HQ.
ext , I needed to swap Engine,Fit quaife gearbox,GT35R turbo Setup,Front mount intercooler,Rad,Exhaust,HiSpec Brakes,Link G3 ECU,Ecu loom,Steering wheel,Track rod ends,Front and rear anti roll bars.
I also bought the whiteline caster kit to fit the powder coated wishbones.
I started removing parts from the old rusty shell - Airfilter,headlights,Ecu,Down pipe,Backbox,Rad,Intercooler + all piping, Battery.
Hopefully not much more until the engine can be dropped.
Engine nice and clean ready for fitting into clean shell.
Quick bhp
Power was testing on some road dyno software which gave me the power at the wheels.
To work out power at the fly 20-25% for the transmission losss = 458hp - 477hp
These were taken at 1.5bar intakes temps at 19oC , 7000rpm rev limit
Engine getting fitted in HQ garage.
Next on the list to change was
Small P/S pipe
Connect large P/S pipe
Fit exhaust
Track rod ends
Radiator
Intercooler
intercooler pipework
Gearbox / Transfer Box Oils
Rear brakes
Brake fluid change
Clutch Fluid check
cv boots
drive shafts
Anti Roll Bars
All together, Some pics Corbs took on the high suspension.
Finished
And went to a few Shows
After the shows I had a problem with the radiator leaking, and the stainless manifold cracking so bought a new manifold and custom radiator and put back together, It was running well with new rad and manifold. I only did a few hundred miles, as i wanted to park up now over winter until the salt was gone.
Back on the road..
The manifold cracked again so ordered my 3rd manifold.
This time I Ordered a stainless cast top mount, Treadstone - 304 Cast Stainlss Turbo Manifold
This should last longer than the low cost ones, but still give good flow.
It moved the positon of the turbo a bit which means other bits needed to be redone.
All the studs were cleaned, and the manifold held on with some nice copper plated locking nuts !
Rad to engine block pipe was re-made - as turbo now in the way.
Evething I could get to cleaned and painted until I got bored
The filler needed to be reposition on the radiator dur to the turbo move.
Got everything bolted on , went for a test run, the the clutch slave cylinder failed :(
So ordered a new one fixed the problem so remade the loom for the ECU to get rid of that nasty tape the standard one has.
Ait filter repositioned
Fitted new read disc's + pads , wastegate fitted , screamer pipe moded , drivers side door controls fixed, new plugs , CV bootx checkdc and changed.
And the Pulsar is ready after 18 months ?
Rocker cover repaint
DONE!
Last edit: 14 years 2 weeks ago by gtir350.
18 years 2 weeks ago #23410 by Mr. G
Replied by Mr. G on topic Re:Latest GTiR
Your car is getting like Trigger's broom off \"Only Fools And Horses\".........\"It's had a few new stales and heads.....but ive had the same brush for years\".................lol
Nice to hear Dave..........willbe cool when transplants carried out..........
18 years 2 weeks ago - 18 years 2 weeks ago #23420 by Corbs
Replied by Corbs on topic Re:Latest GTiR
Wow! Nice work! Are you going to be swapping it this winter? If you want a hand then I'm up for helping. And I'll cart your spare SR20DET away as well for no extra cost!
How much of the whiteline kit remains?
What a stupid sig.
Last edit: 18 years 2 weeks ago by Corbs.
18 years 2 weeks ago - 18 years 2 weeks ago #23421 by gtir350
Replied by gtir350 on topic Re:Latest GTiR
Sure you can have have the engine ! , its a 517hp with charge cooling, oh wait I forgot the bloke took it out before I got the shell, shame.
Hes selling the engine for 5k tho.
Last edit: 18 years 2 weeks ago by gtir350.
18 years 2 weeks ago #23435 by Corbs
Is the gearbox, transmission etc still in situ? Or are you going to have to swap that?
What a stupid sig.
17 years 10 months ago #24001 by Mr. G
Ohhhhhhhhh..........shiny.............:)
17 years 10 months ago #24003 by tommo
Replied by tommo on topic Re:Latest GTiR
couple of things steve mentioned tonight... do that oil return/feed properly while its accessible as he struggled while the engine was in the car and check ratios of the new gearbox. apparently there is no speed sensor as such, something to do with speeds being calculated from revs at a certain point. ish. i think. ring him :lol:
17 years 10 months ago #24005 by gtir350
I might have a look at the oil return, dont really want to mess it up tho as it not dripping anymore.
I belive the speed sensor is in the gearbox as thats were the plug is for it anyways?.
That red rocker cover is just on while the engine is getting fitted, as I dont want to scratch my new freshly pained met black one.
Both the new yellow whishbones are now fitted with whiteline anticaster kit and the 300mm hispec brakes.
Not much to do now, just some power steering pipes,holes to cut for intercooler,gearlinkage rods, then the egine can be re-fitted.
17 years 10 months ago #24007 by tommo
ok mate, just double check with him just in case. he thought that may be important if the ratios are different on the new box...
17 years 10 months ago #24123 by gtir350
Pabz wrote:
Sweet nice to see you getting on with it slowly, will be great when it's on the road again
Or not so slowly :) it was only 3 weekend(s) ago when we started to remove the engine from other car.
And ive spend a far few hours cleaning oily bits :)
Ordered some mintex blue racing clutch and brake fluid today, as that what was in the car previouly and dont want to mix it with incorrect fluid(s) !
17 years 10 months ago #24127 by gtirpaul
Replied by gtirpaul on topic Re:Latest GTiR
lookin good dave give us a shout if you need more help p.s ****** tommo :laugh:
17 years 10 months ago #24177 by gtir350
Bit more of an update, i'll put the pics on when i have a bit mote time.
Exhaust is now on ( I think ? )
Intercooler,rad,front bumper bar,prop,gearlinkage,redone the oil return pipe
Should be ready to start up for a test soon, if I can get some gearbox fluid on saturday and manager to put some it !
17 years 10 months ago #24262 by Pabz
Replied by Pabz on topic Re:Latest GTiR
sweet, bet you can't wait to get it back on the road can you?
17 years 9 months ago #24364 by gtir350
Almost finished now !!
Its all running and moving ok, the list of things left to do is...
Brake Fluid.
TAX.
Check and re-check everything.
Test Drive.
17 years 9 months ago #24468 by Pabz
sweet, nearly ring twitching time again dude, bet you can't wait to have it back on the road
Time to create page: 0.173 seconds
