Wheel size
15 years 2 months ago #33079 by vtiadam
Wheel size was created by vtiadam
Planning on getting 17 inch rims on a 35 offset with 7 inch width but curious if I'll have clearance issues with them on my civic alot of sites say I won't but was wondering if eny one on here has done so and had problems ?
15 years 2 months ago #33081 by tommo
Replied by tommo on topic Re: Wheel size
I cant see you having a major issue, usually you can get away with a 7" rim width on most cars nowadays. You only really struggle if you are lowered a lot on an 8" or 9" wheel.
15 years 2 months ago #33083 by Mr. G
Replied by Mr. G on topic Re: Wheel size
Are you running bigger calipers....?
15 years 2 months ago #33095 by vtiadam
Replied by vtiadam on topic Re: Wheel size
A big brake kit will be going on in the near future yes
15 years 2 months ago #33096 by Mr. G
You might need to check offsets and spoke designs............better to make allowances for this before making your wheel choice,be a shame to buy your wheels and find your spokes foul on larger discs or calipers......
15 years 2 months ago #33101 by vtiadam
cool ill check that my bros got the same ones on his lude so should be easy enuf to check
15 years 2 months ago - 15 years 2 months ago #33105 by gtir350
Replied by gtir350 on topic Re: Wheel size
Normal things to check, pcs Is number of studs * distance eg 4*100 , offset is how far the wheel sticks in / out, center bore is what it sounds like, sorry if you know all this, but get it wrong your car will handle like poo.
Sent from my HTC Desire using Tapatalk
Last edit: 15 years 2 months ago by gtir350.
Time to create page: 0.061 seconds
