rotary engine explained
19 years 7 months ago #9831
A rotary engine is an internal combustion engine, like the engine in your car, but it works in a completely different way than the conventional piston engine.
In a piston engine, the same volume of space (the cylinder) alternately does four different jobs -- intake, compression, combustion and exhaust. A rotary engine does these same four jobs, but each one happens in its own part of the housing. It's kind of like having a dedicated cylinder for each of the four jobs, with the piston moving continually from one to the next.
The rotary engine (originally conceived and developed by Dr. Felix Wankel) is sometimes called a Wankel engine, or Wankel rotary engine.
In this article, we'll learn how a rotary engine works. Let's start with the basic principles at work.
Like a piston engine, the rotary engine uses the pressure created when a combination of air and fuel is burned. In a piston engine, that pressure is contained in the cylinders and forces pistons to move back and forth. The connecting rods and crankshaft convert the reciprocating motion of the pistons into rotational motion that can be used to power a car.
In a rotary engine, the pressure of combustion is contained in a chamber formed by part of the housing and sealed in by one face of the triangular rotor, which is what the engine uses instead of pistons.
The rotor and housing of a rotary engine from a Mazda RX-7: These parts replace the pistons, cylinders, valves, connecting rods and camshafts found in piston engines.
The rotor follows a path that looks like something you'd create with a Spirograph. This path keeps each of the three peaks of the rotor in contact with the housing, creating three separate volumes of gas. As the rotor moves around the chamber, each of the three volumes of gas alternately expands and contracts. It is this expansion and contraction that draws air and fuel into the engine, compresses it and makes useful power as the gases expand, and then expels the exhaust.
wikipedia is your friend:
most reconised rotary engine - 13B
13B-Turbo
The 13B-DEI was turbocharged in 1987. It features the newer four-injector fuel injection of the 6PI engine, but lacks that engine's eponymous variable intake system. The twin-scroll turbocharger is fed with a two-stage valve to reduce turbo lag. Output is way up at 185 hp (138 kW) at 6500 rpm and 183 ft·lbf (248 N·m) at 3500 rpm.
13B-REW
A twin-turbocharged version of the 13B, the 13B-REW, became famous for its high output and low weight. The twin Hitachi HT-12 turbos were operated sequentially, with the primary providing boost until 4,500 RPM, and the secondary coming online afterwards. Output eventually reached, and may have exceeded, Japan's "maximum" of 280 hp (208 kW) for the final revision used in the series 8 Mazda RX-7.
rotary engine explained was created by tommo
13B-Turbo
13B-REW
Time to create page: 0.054 seconds
- rotary engine explained
