Larger Injectors
19 years 11 months ago #7831 by Alienfish
Larger Injectors was created by Alienfish
Ok, due to my future plans for my little CG10 Micra, which will be Nitrous Oxide, however I shouldn't need larger injectors due to the extra fuel injector, however, it would be nice to put the 1.6 Almera injectors in on the safe side.
In the near future I will be investing in G-Reddy E-Manage Blue mainly to map for Piper Fast Road Cams, however, up until this point, will the larger 1.6 injectors run fine? Will the ECU be ok with them? Or will it not be able to control them like the standard ones
19 years 11 months ago #7847 by tommo
Replied by tommo on topic Re: Larger Injectors
youll need fuelling control of some variety for definate mate, how much better are CG13 injectors? although seeing as your swapping them you may as well go for 1.6's and back off the fuelling via the safc you've just brought lol
19 years 11 months ago #7848 by Alienfish
Replied by Alienfish on topic Re: Larger Injectors
CG13 uses same injectors as the CG10 :)
I will be using the GA16 injectors.
I'll keep my eye out in scrappy's for them :p
19 years 11 months ago #7850 by E-HK11
Replied by E-HK11 on topic Re: Larger Injectors
i ran p10 injectors as replacement to k11 ones for ages on a stock setup and everything was ok.
Also when getting them from a scrapyard its better just taking the whole p10 feul rail. Then come home put that in a vice and impact drive the injectors out they are in there PROPER SOLID!!
YOU WILL NOT BE ABLE TO HAND SCREW THEM OUT!!!
Supercharged Nissan March
between 110-130bhp! lol
19 years 11 months ago #7852 by Alienfish
I'll keep an eye out, whilst my other is an eye out for a low mileage CG13 ;)
19 years 11 months ago #8011 by Cov_Racer
Replied by Cov_Racer on topic Re: Larger Injectors
Quick little hijack, kinda related, dont suppose you know if the GA14DE injectors are the same size as the GA16DE injectors do you?
19 years 11 months ago #8046 by tommo
being GA series i would imagine they are
but dont quote me ;D
Time to create page: 0.145 seconds
