Garrett Turbochargers Specs
20 years 1 week ago #7525
Dual Ball Bearing GT28 Turbo assembly with internal wastegate assembly. .
64ar turbine with 5 bolt exit. Very very Good response turbo for 4 Cyl applications.
This turbo has a flow capacity of about 280HP.
Compressor Turbine
Turbo CHRA Wh Dia Trim A/R Wh Dia Trim A/R
466541-1 446179-12 60mm 60 0.60 53mm 62 0.64
Dual Ball Bearing GT28RS turbo assembly with T25 style turbine inlet. Comes with internal wastegate pre-assembled.
Compressor Turbine
739548-1 446179-66 60mm 62 0.60 53.8mm 76 0.86
Garrett Turbochargers Specs was created by gtir350
Compressor Turbine
Compressor Turbine
20 years 1 week ago #7551
Replied by Mr. G on topic Re: Garrett Turbochargers Specs
Just ordered a set of sard 550cc injectors,,,,,,,do i need to uprate the fuel pressure regulator ???
Time to create page: 0.080 seconds
- Garrett Turbochargers Specs
