De-Cat
  • teenage-kicks
  • Topic Author
  • Visitor
  • Visitor
20 years 6 months ago #4985 by teenage-kicks
De-Cat was created by teenage-kicks
hi, advise required -
as some of you know i had my car de-cat'ed the other day but i do have a question.
i know this is proberbly a really stupid question but has any noticed if their car smokes more after they had there cat removed? cause mine was smokin like the Proverbial Bast**d when i got home, i don't mean just idleing, but i put it in reverse to get on my driveway and more smoke than usual. i'm 99% sure it's nothing serious as it is just started after i had the cat removed, but just wanted to check with you guys.
tony
  • jimlude98
  • Topic Author
  • Visitor
  • Visitor
20 years 6 months ago #4986 by jimlude98
Replied by jimlude98 on topic Re: De-Cat
you will prob nitice a bit more cause the cat is no longer there to take the harmful gases out the exhaust system, i believe the gases will also exit the car hotter with the cat removed and with it been rather cold last night it may of just been heat vapour you were seeing fella.
  • hadyn
  • Topic Author
  • Visitor
  • Visitor
20 years 6 months ago #5009 by hadyn
Replied by hadyn on topic Re: De-Cat
What colour is the smoke?
White is usually water/condensation burning off
Bluey/Grey is usually oil burning off
Decatting and the subsequent loss in back pressure can sometimes show up tired valve stem seals in older engines which will smoke a bit as the cat is no longer there to 'catch' the traces of oil that seep past the seals.
  • gtir350
  • Topic Author
  • Visitor
  • Visitor
20 years 6 months ago #5017 by gtir350
Replied by gtir350 on topic Re: De-Cat
You'll get a lot more "steam" from a stainless steel exhaust system.
And with the de-cat it more free to exit the pipes
  • paulo
  • Topic Author
  • Visitor
  • Visitor
20 years 6 months ago #5019 by paulo
Replied by paulo on topic Re: De-Cat
mine throws loads out mate, and i only have a backbox, i wouldn't worry about it, next time your sat behind me in traffic just have a look see how much steam comes out of my exhaust, you could steam vegetables with it
pablo
  • teenage-kicks
  • Topic Author
  • Visitor
  • Visitor
20 years 6 months ago #5062 by teenage-kicks
Replied by teenage-kicks on topic Re: De-Cat
Hi,
the smoke is defernatly white, i did take it to phils on monday, he had a look and said there's nothing to worry about, plus it has settled down i bit now.
thanks for replying guys
cheers
tony
19 years 11 months ago #8016 by Cov_Racer
Replied by Cov_Racer on topic Re: De-Cat
As this thread has a smoke theme i was wondering why the smoke out my exhaust was white. what happened was the seal on number 4 spark plug in the rocker cover wasnt sealing well so oil was getting past the seal and down into the spark plug chamber/tube covering the spark plug in oil, i drained as much as possible with the straw method like you check your washer bottle water level but obviously some oil wasnt able to be removed, so when i took the plug out to clean the oil off it, the oil that was in the bottom went into the combustion chamber, cleaned it all up, put it back together turned the engine on and had a nice plume of white smoke from my exhaust.
My question, it was oil, why was it white smoke?
Thanks, Paul
19 years 11 months ago #8047 by tommo
Replied by tommo on topic Re: De-Cat
thats stumped me lol
dave?! lol
19 years 10 months ago #8050 by gtir350
A large amount of oil will burn pure white, like when a turbo is gone you'll get white smoke pooring out the exhaust,
A smaller amount of oil burning will be blueish
Time to create page: 0.171 seconds
