ENGINEERING THE CAM
18 years 1 week ago #24858 by gtir350
ENGINEERING THE CAM was created by gtir350
Found this bit of info on cam's
Text taken from this link...
www.performancetuner.co.uk/site/494/Tech...rmance_Camshaft.aspx
ENGINEERING THE CAM
John Crabb, Piper Cams’ Technical Director, explains the process behind engineering a new camshaft: “We basically design valve motion, we just go back to design the shape of the cam and that valve motion is all about how much air you flow with everything bolted on.
“The first thing we do with a new camshaft, is put the cylinder head on a flow bench to see how efficient the ports are. Generally we can always make it better because the standard OE parts have different design criteria – such as emissions, etc. After we’ve flowed the head, we then put the inlet manifold on to see where the weakest link is – to evaluate how efficient the standard port is – and then we do the same with the exhaust. There’s no point just flowing the head, because all the other components reduce the flow rate.
“You’ve got to address the engine’s needs, which is why we make all the exhausts too – and there’s hardly anyone who does that. Once you’ve sorted out the cylinder head and start reassembling it, you can see where the bottleneck is because you’re losing power – and that’s where you spend the money. It’s amazing how many people spend a lot of money on a cylinder head and then bolt the restriction back onto it afterwards.
“Ideally you don’t want the inlet port to be polished because the fuel droplets hang on the wall and you use that to break or mix the air with the fuel (unless you’re running fuel injection which runs under greater pressure of course). It’s all about the shape of the port, getting the mixture in as smoothly and quickly as possible, otherwise the airflow can vortex and break away. You can actually hear it in the port – it makes a horrible squealing noise when it all goes out of control.
“After that you do a curve which shows you when the air rolls over at a certain valve lift – this allows you to design a camshaft with the maximum lift for the airflow. The OE component will be quite a way short of optimised lift – say the airflow dictates a 10mm lift, the OE lift will be around 8.5-9mm. We can neutralise that lift and the area. As for exhaust flow, it should be at 80 per cent of the inlet flow.”
What about performance tuned cylinder heads? “The problem is that everyone ports their cylinder heads differently. Our Fast Road cams aren’t a problem because they’re designed for standard cylinder heads and we know what their flow rates are, so generally they’ll work quite well. Beyond that, after people have fitted bigger valves and changed the port sizes, you have to make a ‘guesstimation’. Although most companies know what they’re doing, so it should flow X-amount more air and it should peak over at 600 or 500 thou’. Unless you’ve got all the valve gear, inlet and exhaust manifolds you can’t get it exactly right, so you have to compromise,” says John.
“What we look at next is valve train geometry – whether it’s directly operated or whether it’s push-rod. If you start accelerating the pushrods too quickly, you get buckling and it all gets out of control. So after we’ve designed a camshaft profile, we go back and make sure that there aren’t any harmonics or problems with the push-rods, etc. The standard valve springs also have to be inspected, again to make sure that they can cope and if they can’t, then we have to design a new valve spring with a suitable spring cap.
“When we design the valve springs we make sure that they match standard OE fitted length with a spring cap, so the customer doesn’t have to machine the platform. This is because if you design something which requires machining then it’s expensive, plus it can be hard to find a local machine shop, so we try and package everything in without it needing machining.”
Lift and duration are probably two of the most commonly heard pieces of camshaft parlance (see sidebar), but is it possible to have too much of a good thing? Well, certainly with duration – which is the time the valve is open from the start to the end of the cycle. You want as short a duration as is physically possible (which also reduces the amount of overlap) and this is certainly the current thinking behind modern higher lift cams. The danger with a long duration is that the valves are open for longer at Top Dead Centre (TDC) so the mixture goes straight in and then out, making it very inefficient.
“The problem when you try to combine high lift with a short duration, is that there isn’t much time,” explains John. “This means that everything has to speed up and it can lead to problems with dynamics and positive acceleration where the valve tops can break off.”
Lift is also another thing which can be supplied in excess, particularly when airflow is dropping off. There’s little point in going for a huge amount of lift if there isn’t the available airflow to utilise it; in effect all that is happening is that everything is being put under unnecessary additional stress.
“Airflow is basically governed by the minimum port diameter and the size of the valve – there is a maximum volume it can flow. The smaller the inlet port, the faster the speed of airflow – an inlet with a 1 inch diameter equals an airspeed of 110 metres per second. Again it’s important to get the right port area to valve area for maximum flow,” says John.
Become conversant in cams and the message is a simple one. If you are intending to modify your head, install a cam which has been designed to suit the spec of your cylinder head. Then you can sit back and be confident that you are reaping genuine power gains from an optimised tuned cylinder head. Just remember to give the camshaft its fair dues...
THE CAMSHAFT DICTIONARY
Lift: This figure refers to either cam lift or valve lift. When it refers to valve lift, the figure is calculated by multiplying the cam lift by the rocker ratio.
Duration: Measured in crankshaft degrees, this figure refers to the length of time the valve is off its seat; this is calculated by adding the timing figures together and then adding 180.
Overlap: This is when both the inlet and exhaust valves are open at the same time; it is measured in crankshaft degrees. Overlap is calculated by adding the opening number of the inlet cam to the closing number of the exhaust cam – these are the first and last figures of the cam timing. Usually, it’s a case of the greater the overlap (ie the higher the number) the hotter the camshaft.
Cam timing: This is the position of the camshaft relative to the crankshaft. This is expressed as the number of degrees that full lift occurs after Top Dead Centre (TDC) in the case of the inlet and before TDC for the exhaust. Cam timing is calculated by dividing the duration figure by two.
Valve timing: The opening and closing position of inlet and exhaust valves relative to the crankshaft as figures before and after TDC and Bottom Dead Centre (BDC).
Lobe angle: Is the angle between the inlet and exhaust lobe which is measured in degrees.
Ramp: Is the part of the profile that gradually takes up the valve clearance and slack in the valve train, before the valve is actually lifted from the seat. It also rests the valve gently back onto the seat after the closing flank. Mechanical profiles use a much higher ramp than mechanical ones because the hydraulic cam follower should be in contact with the lobe at all times. The height of the ramp dictates what the measurement the valve clearances should be set at.
Flank: Is the part of the profile between the ramp and the nose, which is the most important part of the whole design. The flank controls the velocity and acceleration of the valve train. The rate of acceleration and deceleration must be within the working limits of the valve spring – too much and valve float will occur. Generally, high acceleration and velocity figures are beneficial to engine performance.
Nose radius: The larger the nose radius the better, because this minimises stresses.
Dwell: As the valve reaches full lift it will stop moving for a few degrees before starting to drop back towards the seat – this is the period known as dwell. When checking the cam timing using the full lift figure method, the mid-point of the dwell should be taken as exact full lift.
Rocker ratio: Is the ratio between valve motion versus cam follower motion. Only applicable to pushrod engines which typically use a ratio between 1.1:1 and 2.0:1.
Overall height: Is the measurement taken in a straight line from the nose of the lobe to the bottom of the base circle through its centre.
Base circle diameter: Is the measurement across the lobe, calculated by measuring the overall height and subtracting the cam lift.
Time to create page: 0.052 seconds
