Bee*R Rev Limiter
19 years 1 month ago #14721
by tom_hunt
Bee*R Rev Limiter was created by tom_hunt
Hay guys
Iv done a serch and not found anything on this site.
Do any of you no much about the bee*R Rev Limiters you can get?? Iv seen videos of them and i can get one rather cheap at the min. Been told not good for every day use but can be turnd on and off.
What would you lot suggest? get it or leave?
Tom
Tom
19 years 1 month ago #14722
Replied by gtir350 on topic Re:Bee*R Rev Limiter
Normaly a good idea to get an antermarket Rev limiter that will cut the spark rather than cut the petrol ( as the standard system does )
As for the make i'm not sure you'll be able to tell much diffrence, Some come with extra options like two stage limit .
This is the sales spec for the Bee*
This is Bee*R’s popular two-stage ignition cutting rev-limiter. It is used to prevent damage arising from over-revving your engine. Part of the reason for its popularity is the large flames and loud bangs it produces from the exhaust when active!
The way in which it works differs from the factory rev limiter in that it is an ignition cut, as opposed to a fuel cut. The reason for this is because if an engine (particularly turbocharged) regularly hits a fuel-cut rev limit (such as in high performance driving, or particularly drifting) engine damage can arise due to the lean condition produced when the original ECU shuts off the fuel pump. The BEE*R rev-limiter allows fuel to pass into the engine still, limiting engine speed by disabling the ignition signal. The Bee*R rev limiter is fully adjustable in 500rpm increments, for safety reasons allowing only a lower rev-limit to be configured than standard. If you have spent a lot of money tuning your engine, or are running at high RPM’s for extended periods of time, it could be recommended to run a lower rev-limit to prolong engine life. Both Formula 1 and JGTC cars use ignition cutting rev limiters, so it is a fully race proven concept.
The Bee*R can also be used as a “two stage rev limiter”, as an aid for launching your car. The Bee*R is configurable for two different rev-limits. A lower rev limit can be activated by a switch, the handbrake switch often being used. This configurable lower limit, can be set to the optimum RPM to launch your particular car from in 500rpm increments. When the handbrake is released, the usual rev limit comes into action, allowing quick launches, and full performance down the strip.
The Bee*R rev-limiter has another final neat feature. The gain control knob allows you to adjust the frequency of the ignition cut. This in turn changes the frequency and sound of the flames and bangs from your exhaust!
Available for use with all rotary, 4 and 6 cylinder engines. (No V8 application)
http://www.neweraparts.com/DesktopModules/CATALooKStore/MakeThumbImage.aspx?ID=%2fPortals%2f0%2fMay+power+resized_1.JPG&PORTALID=0<br><br>Post edited by: gtir350, at: 2007/06/14 07:35
19 years 1 month ago #14723
Replied by PureEvilDevelopments on topic Re:Bee*R Rev Limiter
reading that id say worth a purchase for sure
19 years 1 month ago #14726
by tom_hunt
Replied by tom_hunt on topic Re:Bee*R Rev Limiter
Cheers for that info.
So would you say good for every day use? I dont hardly go out in my car but some times i could use it everyday for a week or two easy.
Tom
Tom
19 years 1 month ago #14728
yeah cause u can set your normal rev limit with it and the set stage 2 up as a launch system for the drag strip with the use of the had braek switch
19 years 1 month ago #14729
by tom_hunt
Awsome!
Im just going to buy one this minute! Will be here on Monday the guy reckens so will have it fitted next week aswell
Carnt wait
Cheers for the info
Tom
Cheers for the info
Tom
19 years 1 month ago #14765
.......Worth buying any way.......looks cool as f**k
Replied by Mr. G on topic Re:Bee*R Rev Limiter
19 years 1 month ago #14773
by tom_hunt
Just got it thru the post. Carnt wait to install it.
Tom
Tom
19 years 1 month ago #14798
by tom_hunt
Could one of you answer me this quickly please
I want to fit my Bee*R Rev Limiter soon but was wondering that if i undo the ECU will this interfear with the Uni Chip i have fitted like will it wipe it all or something?
Tom
Tom
19 years 1 month ago #14799
Nope.
The Unichip will save the map you have stored, so no needto worry about loosing the settings when you disconnect the battery / ECU<br><br>Post edited by: gtir350, at: 2007/06/19 19:52
Time to create page: 0.157 seconds
- Bee*R Rev Limiter
