Nissan Pulsar Part Numbers
- gtir350
- Topic Author
- Visitor
21 years 1 month ago #2792
Nissan Pulsar Part Numbers was created by gtir350
Page 1 <br>Crank thrust washer---12280-60j00 £9.70 set <br>front crank seal---13510-v7200 £5.40 <br>rear crank seal----12279-18v00 £19.50 <br>Hub unit 402202-50y10 £125.00 <br>front hub seal 40232-50y10 £5.00 <br>dust seal 40227-50y10 £5.00 <br>front wheel bearing 40210-50y05 £35.00 <br>Clutch Master Cylinder= 3061054c50 =£74.60 +vat <br>Description Year Colour(s) Part Code Part Number <br>Front Ornament (P Badge) 10/90 -10/92 62311 62892-62C00 <br>Front Ornament 10/92 - 01/93 62311 62892-73C00 <br>Front Ornament 01/93 - 62311 62892-73C60 <br>Rear Air Spoiler Assy-Roof 10/90 - KH3 96030R 96030-54C25 <br>Rear Air Spoiler Assy-Roof 10/90 - AJ4 96030R 96030-54C26 <br>Rear Air Spoiler Assy-Roof 10/90 - 05/94 TJ1 96030R 96030-54C27 <br>Rear Air Spoiler Assy-Roof 10/90 - 10/92 KJ7 96030R 96030-54C28 <br>Rear Air Spoiler Assy-Roof 10/90 - 531 96030R 96030-54C85 <br>Rear Air Spoiler Assy-Roof 10/92 - FM0 96030R 96030-54C27 <br>Tow Hole Cover 10/90 - AJ4 62228 62228-54C00 <br>Tow Hole Cover 10/90 - KH3 62228 62228-54C02 <br>Tow Hole Cover 10/90 - TJ1 62228 62228-54C03 <br>Tow Hole Cover 10/90 - KJ7 62228 62228-54C04 <br>Tow Hole Cover 10/90 - 531 62228 62228-54C05 <br>Tow Hole Cover 10/92 - FM0 62228 62228-74C02 <br>Front Bumper (Fascia Kit) 10/90 - 05/92 AJ4, KJ7, 531 62650S 62022-54C25 <br>Front Bumper (Fascia Kit) 10/90 - 05/92 KH3, TJ1 62650S 62022-54C26 <br>Bonnet (No ventts just Holes) All All 65100 65100-653C0 <br>Bonnet ventt Main (Air Intake) All All 65815 65852-54C00 <br>Bonnet vent (Louver) RH 10/90 - AJ4 65810J 65832-54C00 <br>Bonnet vent (Louver) RH 10/90 - KH3 65810J 65832-54C02 <br>Bonnet vent (Louver) RH 10/90 - TJ1 65810J 65832-54C03 <br>Bonnet vent (Louver) RH 10/90 - 10/92 KJ7 65810J 65832-54C04 <br>Bonnet vent (Louver) RH 10/90 - 531 65810J 65832-54C05 <br>Bonnet vent (Louver) RH 10/92 - FM0 65810J 65832-54C08 <br>Bonnet vent (Louver) LH 10/90 - AJ4 65811J 65833-54C00 <br>Bonnet vent (Louver) LH 10/90 - KH3 65811J 65833-54C02 <br>Bonnet vent (Louver) LH 10/90 - TJ1 65811J 65833-54C03 <br>Bonnet vent (Louver) LH 10/90 - 10/92 KJ7 65811J 65833-54C04 <br>Bonnet vent (Louver) LH 10/90 - 531 65811J 65833-54C05 <br>Bonnet vent (Louver) LH 10/92 - FM0 65811J 65833-54C08 <br>Front Grille Kit 10/90 - AJ4 62301 62310-54C25 <br>Front Grille Kit 10/90 - KH3 62301 62310-54C27 <br>Front Grille Kit 10/90 - TJ1 62301 62310-54C28 <br>Front Grille Kit 10/90 - KJ7 62301 62310-54C29 <br>Front Grille Kit 10/90 - 531 62301 62310-54C91 <br>Rear Number Plate surround 10/90 - 05/92 90810M 90810-62C10 <br>Rear Number Plate surround 05/92 - 90810M 90810-62C00 <br>Rear Bumper (Fascia Kit) 10/90 - 05/92 All 85010S 85022-50C25 <br>Rear Bumper (Fascia Kit) 10/92 - All 85010S 85022-50C26 <br>Rear Window (Glass) All All 90313 90300-50C01 <br>Air Filter element replacement All All 16546 16546-V0100 <br>Air Filter (Air Box) All All 16500 16500-54C10 <br>MAF (Mass Air Flow Meter) All All 22680 22680-54C00 <br>Radiator Assem All All 21400 21410-63C00 <br>Radiator Hose (Lower) All All 21503 21503-54C01 <br>Radiator Hose (Upper) All All 21501 21501-54C00 <br>Front Strut Kit (RH) - No ABS 10/90 - 05/92 All 54302K 54302-69C25
- gtir350
- Topic Author
- Visitor
21 years 1 month ago #2793
Replied by gtir350 on topic Re: Nissan Pulsar Part Numbers
Part 2<br>FUEL FILTER 1640053J10 £10.20 <br>OIL FILTER 1520870J00 £5.20 <br>WASHER,DRAIN 1102601M02 £1.10 <br>HT LEADS 2245054C27 £42.00 <br>REPAIR KIT DUST(p/s front hub side)3924163Y25 £22.00 <br>RADIATOR ASSY 2141066Y01 £189(thin) <br>RADIATOR ASSY 21410-63C00 £???(thick) <br>ROTOR,HEAD 2215754C01 £6.40 <br>CAP,DISTRIBUTOR 2216253J00 £15.40 <br>PUMP-WATER ASSY 21010-54C00 £41.00? <br>LAMBDA SENSOR 22690-54C00 £86.00? <br>GASKET-ROCKER C 1327053J05 £7.20 <br>GASKET-TURBO CH 1444526E00 £15.20 <br>GASKET-EXHAUST 2069158E01 £2.90 <br>GASKET 1441517M00 £11.70 <br>GEARBOX OIL SEAL 3834256E00 £5.20 <br>TRANSFERBOX OIL SEAL 33111-56E00 £7.90 <br>COIL LEAD 22450-53J11 £12.40 <br>STRUT KIT-FRONT SUSPENSION, RH______54302-69C25 £116 + vat <br>STRUT KIT-FRONT SUSPENSION, LH______54303-69C25 £116 + vat <br>STRUT KIT-REAR SUSPENSION, RH______55302-69C25 £116 + vat <br>STRUT KIT-REAR SUSPENSION, LH______55303-69C25 £116 + vat <br>HEATER CONTROL LIGHT BOLB - 25196-89905 - £3.20 +vat each <br>THERMOSTAT 21200-53J00 £13.90+vat <br>OIL PRESSURE SENDER V507032J00 £69.90 <br>DROP RESISTOR 22698 54c00 £81 inc vat <br>VALVE STEM OIL SEALS N13207D4201 and N1320753F00 £2.90 each <br>CYLINDER HEAD BOLTS 11056-54C00 £4.70 each <br>MAIN BEARINGS 12207-54c00 £8.70 each(pair) <br>CRANK THRUST WASHER 12280-60j00 £9.70 set <br>FRONT CRANK SEAL 13510-v7200 £5.40 <br>REAR CRANK SEAL 12279-18v00 £19.50 <br>SERV MAN VOL1 (ENG)____SM1E1N4BGO £84.60 (RARE AS ROCKING HORSE SH*T) +vat <br>SERV MAN VOL2________SM1E2N4BGO £66.60 +vat <br>HAND BRAKE SWITCH____3601150Y00 £ 7.20 +vat <br>FUEL CABLE THING______H465950A05 £ 9.70 +vat (RELEASE MECHANISM IN BOOT) <br>DISTRIBUTOR POWER TRANSISTOR _______2202053J10 £48 +VAT <br>IDLE AIR CONTROL VALVE AIR REGULATOR (BOLTED ONTO THE CYLINDER HEAD UNDER THE I.A.C.V WITH A BLACK SIDE TO IT) _______22660-93L00 £85.30+VAT <br>STRUT KIT-FRONT SUSPENSION, RH______54302-69C25 £116 + vat <br>STRUT KIT-FRONT SUSPENSION, LH______54303-69C25 £116 + vat <br>STRUT KIT-REAR SUSPENSION, RH______55302-69C25 £116 + vat <br>STRUT KIT-REAR SUSPENSION, LH______55303-69C25 £116 + vat <br>oil pressure sender V507032J00 £69.90 <br>drop resistor part no 22698 54c00 £81 inc vat <br>Valve stem oil seals
N13207D4201 and N1320753F00 £2.90 each <br>Cylinder head bolts
11056-54C00 £4.70 each <br>Inlet manifold gasket----16175-54c00 £4.40 <br>Exhaust manifold gasket---14036-53j00 £14.90 <br>main bearings----12207-54c00 £8.70 each(pair)
- gtir350
- Topic Author
- Visitor
21 years 1 month ago #2794
Part 3<br><br>Front Strut Kit (RH) - With ABS 10/90 - 05/92 All 54302K 54302-69C26 <br>Front Strut Kit (RH) - No ABS 05/92 - All 54302K 54302-69C27 <br>Front Strut Kit (RH) - With ABS 05/92 - All 54302K 54302-69C28 <br>Front Strut Kit (LH) - No ABS 10/90 - 05/92 All 54303K 54303-69C25 <br>Front Strut Kit (LH) - With ABS 10/90 - 05/92 All 54303K 54303-69C26 <br>Front Strut Kit (LH) - No ABS 05/92 - All 54303K 54303-69C27 <br>Front Strut Kit (LH) - With ABS 05/92 - All 54303K 54303-69C28 <br>Rear Stabilizer All All 56230 56230-69C00 <br>Rear Strut Kit (RH) All All 55302K 55302-59C25 <br>Rear Strut Kit (LH) All All 55303K 55303-69C25 <br>Brake Rotor Disc (Front) All All 40207 40206-54C01 <br>Front Wheel Bearing (NSK) All All 40210 40210-50Y00 <br>Front Wheel Bearing (NTN) All All 40210 40210-50Y05 <br>Prop Shaft Assy All All 37000 37000-54C05 <br>Clutch Slave Cylinder Kit All All 30620 30620-80E20 <br>Clutch Tube Assy (MastertoSlave) All All 30650 30850-63C00 <br>Clutch Release Bearing All All 30502 30502-0W720 <br>Clutch Master Cylinder Kit All All 30610 30610-63C52 <br>Clutch Fluid Reservoir (inc Braket) All All 30609 30617-63C00 <br>Transfer Assembley All All 32010M 32010-54C18 <br>Front Differential All All 38711 38411-56E00 <br>Bearing - Diff Side All All 38440N 38440-56E00 <br>Front Driveshaft Kit (LH) (No ABS) All All 39101 39101-63Y01 <br>Front Driveshaft Kit (LH) (With ABS) All All 39101 39101-63Y11 <br>Front Driveshaft Kit (RH) (No ABS) All All 39100M 39100-63Y01 <br>Front Driveshaft Kit (RH) (With ABS) All All 39100M 39100-63Y11 <br>Power Steering Pump Kit All All 49110 49110-54C00 <br>Side Skirt End Cap (RH) All All 76856-50C00 <br>Side Skirt End Cap (LH) All All 76857-50C00 <br>Umbrella is 96546-76M00
Time to create page: 0.032 seconds
Manuals and General Info
- Nissan Pulsar Part Numbers
