Alarm/central locking trouble!!
14 years 4 months ago #33823
by Arnie
Alarm/central locking trouble!! was created by Arnie
Well, since doing the service, the remote central locking no longer works!! The alarm still arms and disarms, but it no longer locks the doors!!! The central locking still works with the key in the lock, but no longer with the alarm!!
Any ideas or thoughts???
14 years 4 months ago #33826
Replied by Mr. G on topic Re: Alarm/central locking trouble!!
Not an expert on this.....i'll have a guess....the keyfob should emit a signal which is picked up by some sort of receiver..?......this receiver should be connected to a number of relays via a form of control unit/chip ,which then tell the various bits to operate.
Since your Alarm is deactivating,and the the doors operate manually,it may be a control relay from the the receiver/control unit.....only a guess,Greg or Jim on here might know for sure....
14 years 4 months ago #33831
Replied by 3gdean on topic Re: Alarm/central locking trouble!!
Had this problem the other day on one at work, will post later.
14 years 4 months ago #33841
Unsure whether it is the same problem, but it is a common fault.
There is a sensor on the back of the lock barrel which is prone to coming off.
Basically door cards off easy enough, couple of clips couple of screws, may need to remove the metal bar that connects to the door strengthener and door handle for space.
Should be able to see if the sensor is on the back of the lock barrel, if it isn't they can be a pain in the ass to get back on, need to make sure "the moon" shape locates properly and clicks back into place.
Hope its an easy solve.
14 years 4 months ago #33844
by Arnie
Replied by Arnie on topic Re: Alarm/central locking trouble!!
Cheers Dean, I'll try and have a look tomorrow. I've also been told it could be a fuse fitted when the alarm was installed. Apparently the alarm and the central locking are on sepererate circuits with seperate fuses so it could be the fuse that's gone!! Hopefully!!
14 years 4 months ago #33858
Anyluck with the fuses???
14 years 4 months ago #33859
by Arnie
Can't seem to find any!! The only thing I can find is the central locking relay, which I assume is ok as the central locking is still working when using the key!! Very strange!!
Time to create page: 0.338 seconds
Electrical
- Alarm/central locking trouble!!
