Battery trouble!!
14 years 6 months ago #33490 by Arnie
Battery trouble!! was created by Arnie
My battery on the Rex keeps dying. It only takes a week or two before it's too flat to start the car!! I've checked the alternator which is charging it fine, I've checked the draw on the battery while it's standing and it's next to nothing! I've had a drop test on the battery and it's not the battery either!! I'm at a dead end!! Any ideas peeps??
14 years 6 months ago #33498 by 3gdean
Replied by 3gdean on topic Re: Battery trouble!!
No eBay APP ID and/or Cert ID defined in Kunena configurationi have no useful info, but dave recently go one of these.
Will be getting one for mine as well.
14 years 6 months ago #33508 by Mr. G
Replied by Mr. G on topic Re: Battery trouble!!
Something may be drawing battery power constantly........so even though your alternator is topping it up it may not be enough....???
14 years 6 months ago - 14 years 6 months ago #33519 by Arnie
Replied by Arnie on topic Re: Battery trouble!!
3gdean wrote: i have no useful info, but dave recently go one of these.
My old man came home with one the other day!! He says I can use it to keep it topped up!!
Mr. G wrote: Something may be drawing battery power constantly........so even though your alternator is topping it up it may not be enough....???
That's what I'm beginning to think. I'm going to drain and recharge the battery and then use a multimeter in series with the battery to see exactly how much current is being drawn while she's standing. If worst come to worst I'lljust have to fitt a battery kill switch to isolate it when not in use! Lat time I did it I just put it across the battery which apparently won't give a true reading!!
Last edit: 14 years 6 months ago by Arnie.
14 years 6 months ago #33528 by sausagefingers
I have the same problem with the corolla, only since I have stopped using it in the week, how often do u use the Rex? I'm looking into mine as I don't want the same thing to happen when I've spent on an optima yellow top, will let u know if I come up with any thing, I'm thinking it's the alarm systems led but common sense says it would take weeks for a single les to kill a car battery.
Greg
14 years 6 months ago #33538 by Arnie
After a bit of investigative work involving the battery and a 12v coolbox, I'm thinking my battery has a cell down. I'm taking it to my local autoelectrician tomorrow to get a drop/shunt test on it which will hopefully determine if it is tatered or not!! As you say Greg, it would take many weeks for the alarm LED to kill a battery, there are other things that draw from it too though, such as the stereo from it's permanent live for it's memory, some ECUs draw current constantly as they have a permanent live too. It might be worth getting the battery tested in case it is faulty. That's my next step.
14 years 6 months ago #33542 by sausagefingers
yeah true, i think mine is just knackered after 2 winters of very little use and freezing weather so will get a new one when the weather picks up i think :)
Time to create page: 0.103 seconds
